Which ceiling mount to buy?
Discussion in 'Projectors, Screens & Video Processors' started by jlanng, Dec 15, 2017.
  1. jlanng
    jlanng
    Aug 20, 2001
    I'm in the market for a ceiling mount, that needs to come down a fair way, but also be easily retractable. I don't want to put my JVC projector on one of the cheap flimsy ones on ebay / amazon. What mounts / brands should I be looking at?
    Ta
  2. Thatsnotmynaim
    Thatsnotmynaim
    Jun 21, 2004
    4,264
    137
    Middle Earth
    +844
  3. jfinnie
    jfinnie
    Oct 1, 2004
    4,517
    Norwich
    +1,895
    How do you mean "retractable"? Sounds like you're looking more for a projector lift than a projector mount, as mounts are not usually retractable.
    If you are just after a standard mount, Peerless mounts can go on the end of a pole (either fixed length or adjustable) which can give extra drop. I like my Peerless mount. The Peerless mounts mate nice and easily, meaning it is an easy job for one person of reasonable strength to get a PJ in / out of the mount mechanism.
  4. Sunshinewelly
    Sunshinewelly
    Dec 1, 2005
    5,108
    +483
    I would only trust a JVC with a peerless mount. Those jvcs are heavy
