Which CAT6 Cable
Discussion in 'Home Cinema Buying & Building' started by miles_boro, Aug 8, 2013.
  1. miles_boro
    miles_boro
    Apr 22, 2007
    494
    +14
    I'm wanting to buy some CAT6 cable, possibly 2 x 305m reels.
    The prices range from £60 to £150 per reel.
    Is there anything I should look out for?
  2. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
    We mainly use Excel, not the cheapest but never had any problems with it.
    They also do a paired real so you can run two runs at the same time that is very useful.
    Seb
  3. miles_boro
    miles_boro
    Apr 22, 2007
    494
    +14
    Thanks Seb. Slightly more than I wanted to pay?
    This is the cheapest I have found:
    RJ45 Network Lan Cat5e Cat6 Gigabit Patch Bulk PC Cable 30M 40M 50M 60M100M 150M | eBay
    £19.59 for 150m so I could get 600m for just short of £80.
    Alternatively something like this:
    NEW!! 305m ROLL Network Cat6 Ethernet RJ45 Cable Solid Reel LOW SMOKE | eBay
    This says it's not CCA and would cost me £180 for 600m. Is CCA important?
    What price do I need to pay for a home network? What about something in between at about £70 per 305m?
  4. Member 581642
    Member 581642
    Jan 3, 2012
    11,106
    +2,501
