Which CAT5 cable?
Discussion in 'Xbox Forums' started by Grumpy Boy, Jan 24, 2008.
  1. Grumpy Boy
    Grumpy Boy
    Jan 4, 2008
    121
    Llanelli
    +10
    I was looking to change my CAT5 cable I use to connect my 360. The one I am using I "borrowed" it from work. It was in bad condition when I got it and it has slowly fallen apart.
    I had a quick look at some cabling web sites and there are quite a few different types CAT5, CAT5e (which I believe is the newer version). I have also seen CAT6 which seems to have superseded CAT5 and is backward compatible but with higher specification regarding signal to noise etc.
    Then there is the crossover and straight wired.
    Basically, I need a cable about 5m long and would like to get a good quality cable so I can minimise and data loss/degredation. Is it better to go sheilded?. It might be over kill but I would rather spend £1 more (the cables are dirt cheap - even the high performance Belkin ones), and get a cable the is way to good for the job than get one that is working to its upper limits.
    Just realised I didn't post in the Hardware section - sorry. can the mods move it?.
  2. hooj
    hooj
    Oct 7, 2002
    64
    Standard straight through Cat5e will be fine.
    No need for shielding, unless its next to a source of interference.
  3. daveon
    daveon
    Mar 31, 2005
    1,635
    Washington
    +126
    Personally I would say that for normal home use, i.e. connecting your 360 to a router you don't need anything over and above bog standard CAT5 Ethernet cable.
    For your reference a cross over cable allow you to connect two devices (xbox 360s in this case) to each other without the need for any additional networking devices such as router, switch or a hub.
  4. Just Me
    Just Me
    Oct 16, 2007
    177
    Bromley, Kent
    +4
  5. Grumpy Boy
    Grumpy Boy
    Jan 4, 2008
    121
    Llanelli
    +10
    Thanks for the speedy replies.
    So a standard straight cable (I won't be networking 360's together) should do. The cable will be running behind my 37" plasma then across the floor to the router (I only connect it up when I go online & kids are in bed). Will the Screen/near by Sky+, Wii, DVD recorder kit cause enough interference to require sheilding. Like I said, there does only seem to be a few pounds between the cheapest old undbranded CAT5 and the top price branded sheilded CAT5e.
  6. smallclanger
    smallclanger
    May 9, 2007
    2,246
    Southampton
    +463
    I've not tried it but I've read in many places that you dont need cross over cables or extra equipment just to connect 2 xboxes as the network adapter is auto sensing.
  7. Grumpy Boy
    Grumpy Boy
    Jan 4, 2008
    121
    Llanelli
    +10
  8. doublej
    doublej
    Jul 3, 2005
    122
    +13
    ....mate, it won't make a blind bit of difference what cable you use. I will buy the 5m cat v cable of you're choice if you find any difference whatsover.
    Think about it............................................think about the journey taken by the data from your xbox, .......to the telephone exchange (3km on a single strand of copper - strung across the street using old wooden poles (unless your fibre cable)).....then to xbox live servers......
    ....steal another from work and sleep well at night, know the laws of physics are on your side.
  9. Desmo
    Desmo
    Jan 4, 2001
    14,562
    Braintree, Essex.
    +6,665
    Seriously, just grab some bog standard cat5 and whack it in. If it doesn't work, I'll personally pop to your house and give you a free chocolate bar :D
  10. RBJTech
    RBJTech
    May 7, 2004
    583
    43
    Kent, England
    +101
    Correct - the ports on the back of the 360 are auto MDI-X ports which basically means it will internally switch the wires over until it gets a link connection - so no need to buy a 'special' X-over cable. Also works the other way - ie you used a X-over cable when you should have used a straight through ...
    Either way - it'll work.. :)
    PS - for info - most modern switches have auto MDI-X ports on them as well - they will all negiotate with the end device and give you a connection even if you don't have the 'proper' cable.
  11. Switch625
    Switch625
    Jan 15, 2005
    1,493
    +183
    I've used Cable Universe a few times with no problems (I'm not advertising them, I swear!)
    www.cableuniverse.co.uk
  12. RandomLee
    RandomLee
    Feb 17, 2006
    9,175
    Just check my IP address
    +2,948
    I used them a few times with no probs at all. Good service :smashin:
