which car camera to buy?
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by jason g, Jun 13, 2015.
  1. jason g
    jason g
    Jan 8, 2006
    16,118
    Theatre Of Dreams.
    +3,807
    im looking for a car camera for my dad but i have no idea what to look for, i need to be able to take the footage from the camera onto my laptop if needed.
    i am also unsure as to what is best required like a motion detector or a live camera from when the car starts/stops.
    card type size im not sure about either, and how to transfer from camera to laptop so i would need some clear advice on that.
    i don't think audio is needed unless someone explains why it is.
    i think most cameras stick onto a windscreen so it must be one that will stick but also be able to be removed as it won't be left in the car when nobody is in it.
    it needs to be a simple device, not too dear but i can pay the extra if needed as i want a good camera.
    i have looked at different types but reviews put me off most of them but i need to buy one so i'll have to decide no matter what.
    it will also need to be one that plugs into the lighter socket as battery ones won't be good enough.
    any advice you can give on either the cameras in general or a specific one would be great as i really have no clue about these cameras.
    thanks.
  2. jason g
    jason g
    Jan 8, 2006
    16,118
    Theatre Of Dreams.
    +3,807
    anyone?
  3. Brava 210
    Brava 210
    Feb 17, 2005
    2,688
    Bristol
    +1,023
  4. jason g
    jason g
    Jan 8, 2006
    16,118
    Theatre Of Dreams.
    +3,807
    thanks, a couple of questions,
    does this plug into the lighter socket or is it just batteries, if batteries is there some sort of meter to show when they are running out and is it rechargable if using batteries.
    how do you get footage if needed from the device onto a laptop for example?
    how do you rate it, any problems?
  5. outoftheknow
    outoftheknow
    Nov 1, 2012
    4,104
    Canberra, Australia
    +1,574
    Some answers in the link - the description gets further down the page with adverts nowadays :)
    About this item
    Product Description
    Additional Features:Audio recording, built-in speaker, auto power save, takes photos while film recording, Details:1 x Li-Polymer rechargeable battery - 470 mAh ( included ), Battery Life Details:Video recording - 0.5 hours, Connector Type:1 x USB 2.0, Memory Card Slot:microSD card, Incident Detection:G-Sensor, Width:6.31 cm, Depth:3.44 cm, Height:6.83 cm, Weight:72.6 g, Display Form Factor:Built-in, Type:2.4" LCD display, Max Operating Temperature:65 °C, Min Operating Temperature:-20 °C, Lens Construction:6 elements, Type:Wide-angle lens - f/1.8, Max View Angle:130 degree(s), Included Memory Card:16 GB microSDHC, Video Capture:H.264 - 1920 x 1080 - 30 fps ¦ H.264 - 1280 x 720 - 30 fps, Memory Card Max Supported Size:32 GB, Memory Card Slot:microSD card, Microphone Operation Mode:Mono, Included Accessories:Car power adapter, adhesive mount, Software:Drivers & Utilities, Transcend DrivePro PC Tool
    With 0.5 hours recording in the battery I reckon it is safe to say you use the car adaptor at all times in a car.
  6. Lokii
    Lokii
    Apr 20, 2015
    3
    Oxon
    Pretty sure I saw a review of the Transcend XX in Auto-Express magazine, on-line, who rated it highly 2014 award winner I think.
    L
