Which Camcorder to Buy?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Peter Jeff, Jan 12, 2005.
  1. Peter Jeff
    Peter Jeff
    Could anyone advise on the best camcorder to buy for the following tasks:
    Copy all my old VHS tapes onto digital and then onto DVD.
    Do I need DV in and DV out?
    I have some old 8mm film I would like to copy and put onto DVD ( with edits) .Would it be possible to run the 8mm film onto a white screen and film that, and add music and speech later??
    Any suggestions would be much appreciated.
  2. thebrummy_one
    thebrummy_one
    Feb 9, 2004
    372
    East London
    +7
    If you want to convert your old VHS you will need AV in/DV out. I believe that it is common practice to copy 8mm in just such a way. Apparently you will need a variable speed projector though so that you can adjust it's playback to reduce the flicker.
    I'm sure there are loads of different cams that has AV/DV conversion functionality, I'm using a Sony PC330 and am very happy with it. (approx £1000)
