wolverine73
Hello everyone.
Just purchased a new freeview box that is Internet enabled and this bit of it works fine however the ordinary signal for tv is not good so purchased a booster box.
Ive connected from the freeview box to the booster using a coaxial cable and I've used the same cable type to connect from the booster to the walksocket aerial input but my freeview receiver says "The receiver is not receiving a signal or the signal is too weak".
I'm not entirely sure that the coaxial cable I have connected up is sufficient - would this be the correct one to use for all connections or are the metal ones more suitable?
Cable Mountain 2m Gold Plated Male to Male Plug to Plug Shielded TV Coaxial Aerial Cable - Black:Amazon.co.uk:Electronics
Thanks in advance for any help
