Which cables are best for the dollar?
Discussion in 'Cables & Switches' started by spideymon, Jun 24, 2004.
  1. spideymon
    spideymon
    Hello out there! I just purchased a rear projection TV (43 inch Toshiba) and need some advice on what brand/quality of cables I should buy? The store clerks seem to really push the "Monster" brand cables which I'm sure are good, but is there anything a bit less...well....pricey that will do the same job? Also, is a high end power-bar with a good signal loss system better or more important?
    Thanks in advance,
    Cheers, Spideymon! :D
  2. FoxyMulder
    FoxyMulder
    I have a Monster cable ( id have to check which model it might be Video 1 not sure but it cost £70 ) anyways its very good build quality and looks stylish, personally i was a sucker for buying it as i believe lower priced cables would have given me the same results but Monster do make decent cables.
    The store clerks push the Monster brand because theyre on commission, personally i advise you do a search online and buy from online as it'll be cheaper.
  3. Tight Git
    Tight Git
    Mar 3, 2004
    6,331
    +597
    Spidy,
    Glad you're not spoiling the ship by using the cheapo scarts provided!
    As you probably realise, you can spend literally hundreds of £ on cables, but the main consideration is whether YOU can tell the difference.
    It's a purely personal choice, but I've found the IXOS flat scart cables to be a good compromise.
    They look good, are well made, fit easily behind the equipment (being flat) and can be obtained in 0.75M lengths.
    Best of all, at around £30, they enable Tight Git to keep his reputation. :thumbsup:
    Hope this helps.
