which cable?
Discussion in 'Cables & Switches' started by trav2006, Dec 29, 2006.
  1. trav2006
    trav2006
    Hi have a goodmans gtv2wlcd and a toshiba satellite l10-33 laptop wish to connect both together,in the tv user guide says use 15 pin cable...connection any ideas what best to get from pc world or comet?
    thanks....
  2. Peridot
    Peridot
    Aug 24, 2004
    2,995
    Newport, South Wales
    +293
    Sounds like you need a standard PC monitor cable. Try a local computer store and you'll get one cheaper than PC World or Comet.
