which Cable?
Discussion in 'Blu-ray & DVD Players & Recorders' started by C227, Jan 21, 2005.
  1. C227
    C227
    Jan 6, 2005
    80
    Ive currently fot my DVD player connected via ths standard scart lead to my Plasma. Been told this is not adequate.
    NOw I could go and buy a proper £60-£70 scart lead.
    However Ive noticed more connections at the back of the DVD player. Are these RGB?
    Does this give better quailty? If so, how much should I pay for a set and which ones are best?
  2. Thunder
    Thunder
    Feb 26, 2004
    1,763
    41
    +14
    What type of player have you got? Are the extra connections red/green/blue phono sockets? If so its a component video connection which would be superior to a RGBs scart as a RCA connection although not ideal is far better than the rather naff scart connector :) Also component video is the method used to store the picture inforamtion on a DVD. You will need a component video cable with three RCA connectors at either end, excellent quality ones are available in the poer buy section of this forum from Mark Grant :thumbsup:
