Which cable for GameCube
Discussion in 'General Video Gaming Chat' started by BIONIC MAN, Apr 2, 2003.
  1. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    1,002
    Nasa
    +45
    Just got my Cube ( About time I know ) :rotfl:
    How should I connect it to my Tosh Tv which I'am just going to use for Gaming , It has 1 Rgb and Component
    At the moment I'am using the Rgb for My Ps2 , So should I go Component for my Cube or Rgb ( Help me to choose ) :p
    If I use the component it only does the Picture Yes , so what will I do for the Sound ? ?
    Also what ais the best cables to go for , notting the Cube with Resi was only £78.99
    :confused:
  2. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    I'd go for the standard Nintendo RGB cable as it will be cheaper and you can pick it up easily.
    Regards,
    Neil.
  3. sharon
    sharon
    I get a much much better picture from progressive scan component out of my gamecube than from RGB but I seem to think that this isn't an option if your cube is a UK/PAL version... so for the best picture buy a US gamecube and US games which support progressive scan!!!!
  4. NeilMcRae
    NeilMcRae
    Sep 2, 2002
    1,191
    41
    London
    +6
    Well progressive scan is a better format so thats why you get a better picture! PAL cubes with a component lead will get a picture
    almost identical to and RGB lead as the PAL cube doesn't support progressive scan.
    Neil.
  5. BIONIC MAN
    BIONIC MAN
    Jun 26, 2002
    1,002
    Nasa
    +45
    Thanks for the reply's about Component , what about the sound
    side ? ?
    And shell I move the Ps2 from Rgb to Component and put Cube to Rgb :confused:
    :smashin:
  6. hdrees
    hdrees
    Aug 19, 2002
    83
    you use the lead you got with the cube just dont use the video lead and use it in scart 3
