J
Jonathan1985
This is my first time here so I'll try and get as much info in as poss.
I've just bought a Toshiba 30" LCD TV and plan to buy a Denon AVR1905 and Denon DVD player to add to it.
Now I always believed that the best way to connect this sort of setup up was to connect everything into the Amp and then connect the TV to the amp. The only worry I have with this setup, is that the Amp only has component and S-Video outputs.
The TV has 3 Scarts/ 2 (Red/White/Yellow)'s/ S-Video/ VGA and DVI inputs, but no component . Now the Denon DVD player I'm looking at has DVI out.
So my question is... which would be the best cable/ connection for me to use considering the setup?
Thanks in advance
Thanks in advance
