Quantcast
Which Budget Projector?
hellarda
Hi guys,
thinking about buying a projector to game on and watch films/use for everyday use.
I have a budget of around £300 but could possibly stretch that slightly.
so yeah whats the best projector for that kind of money?
Preferably with a DVI input but if not then vga will do fine Don't need speakers or a remote or any of that rubbish
cheeeers
EDIT: forgot to say 1920x1080 if possible, doesn't have to be native
hellarda
Also would going second hand be a good idea? I don't mind ebay etc if I will get a better projector for the same money :)
Tight Git
Welcome to the Forum. :)
Sorry you haven't had a reply, but that's usually due to one of two things.
Either your question is so obscure that nobody knows the answer! :eek:
Or it's asked so often that people get fed up typing the same old thing. :thumbsdow
In your case, it's definitely the latter! :laugh:
Can I suggest that you do a search in this section, where there's lots of useful information from KBFern and others.
Please don't hesitate to come back if you need further advice.
Happy viewing! :smashin:
nwgarratt
An HDMI input could be used instead of a DVI one. There are DVI to HDMI cables.
For £300 a second hand 720p is possible such as the Optoma HD700 or HD65. Add another £60 and get a new Optoma HD600 720p. They will downscale a 1080p source to 720p
Play.com - Buy Optoma HD600X
bravogolf
You should scan the classifieds thread on these forums for second hand projectors, there's always a good selection. Failing that, put a wanted thread in there with your requirements and see what comes back :)
funkysnair
defo put up a wanted thread...
i done that and ended up with a sanyo z3 and ceiling mount for under £250 - brilliant cheap projector, never looked back
