I am sending back my Sony 42SX300U LCD rear projection set as have got a fair few dead pixels, I want to replace with a Plasma preferably a Sony but may need to go for a 37" as i need a similar price. is it true that nothing less than a 42" will be any good for HDTV even a panasonic vierra 37"
the new 37PV500 is HD compatible, 37" LCD are also HD compatible but choice is limited only panny are doing a proper HD 37" perhap Philips (but they find a way to screw it all up)
If you want Sony, take Sony. I personally tested Pana 42PW7 and Sony 42M1. I think SONY is better one, more detail, vivid picture and good tones. Take SONY. HD ready products are more expensive, but it worth to take a look.
ermmm....so you don't fancy a plasma that is billed as "Visual Perfection" then mate??? Only a measly 1k too..lol!!! Dil
