Which Budget Computer Should I Buy From These 3?
Discussion in 'Desktop & Laptop Computers Forum' started by rjmartin, Sep 1, 2013.
  1. rjmartin
    rjmartin
    Feb 5, 2009
    262
    +10
    Hey Guys :)
    I am looking to buy an entry level computer and I have about £300 I want to spend on this.
    It will be used mainly for a little light photo editing, some web browsing, watching a few videos on YouTube etc.
    Which out of the following 3 is best and why?
    I am a bit novice-y on computer hardware, is ram more important or the processor speed?
    1) Asus Desktop - £299.99 at Argos
    2) Asus Desktop - £299.00 at Currys
    3) Acer Desktop - £219.59 at Amazon
    With option 3 I would buy a monitor separately.
    Thanks for your help :)
    Cheers, Rob
  2. BigBaws
    BigBaws
    Jun 11, 2010
    1,255
    +30
  3. rjmartin
    rjmartin
    Feb 5, 2009
    262
    +10
    Cheers BigBaws, that looks like a great setup however I do want to buy brand new.
    Out of the 3 which is the best?
  4. BigBaws
    BigBaws
    Jun 11, 2010
    1,255
    +30
    Hi again,Link 1 from Argos does not tell you the GHz & so it would most probibly be the lowest of the AMD dual cores.
    Link 2 is a dual core 2.6GHz.
    Link 3 having a very poor AMD E1 1200 running at 1.4GHz x2 is not good at all.
    Out of the 3,then link 2 is best.
    The 3 of them are very poor in today's market & they are also over priced.
