Which Budget 5.1 Or 6.1 Speakers?
Discussion in 'Home Cinema Speakers' started by vinny, Jul 9, 2005.
  1. vinny
    vinny
    Hi, I'm new to this forum.
    I want to but a low budget (but value for money) 5.1 or 6.1 speakers to connect to my DVD player (not pc soundcard). I can do with a sub 70 sterling for the moment untill the time is right to get more serious and when I can afford it financially to build a good system. I know there are good pc systems out there like Creative, Tsunami, and Altec Lansing that can give adequate performances. But most of them don't have phono inputs and outputs at the back but only jack plugs to connect to a pc soundcard.
    Since I will be visiting the UK soon I would like to know which is the best value for money system with a good performance but I wouldn't want to spend more then 70 sterling.
    Vinny
