Which Brand DVD-RAM disks?
Discussion in 'Blu-ray & DVD Players & Recorders' started by cwoj, Nov 9, 2004.
  1. cwoj
    cwoj
    Hello
    I am the happy owner of a panny DMRE100 DVD Recorder, which DVD Ram disks should i be buying? :lesson:
    Should i go for the carts or just branded ones without?
    What sort of price should i be paying?
    Ta
    Cwoj
  2. apreading
    apreading
    Jun 28, 2004
    283
    +15
    7dayshop do the Panasonic ones in 5 packs for £12, or if you are lucky you can get 10 for £13.50(I think?) as Costco.
    I have tried the Datawrite ones from SVP which are quite a bit cheaper and had no trouble so far.
    I wouldnt bother with the carts to be honest as it makes them so expensive you would be better off with 2 discs and having redundancy.
  3. bobcar
    bobcar
    Oct 3, 2004
    708
    +21
    What do you use them for? Since you have a hard drive then you probably won't need them for time shifting. If you use them for transferring to a PC then without cartridges is usually better because most PC burners don't take cartridges. If you are archiving then DVD-Rs are a lot cheaper. In general cartridges are more robust, I go for double sided as they take up less space.
  4. cwoj
    cwoj
    sometimes i will record a good movie and will want to keep it
  5. kenfowler3966
    kenfowler3966
    Jul 23, 2001
    846
    19
    leeds UK
    +16
    So as the guy above says, why buy -ram discs, if you intend to keep the film it needs to be on -r which should now cost around 25p each, and will play on virtually any other player. I have never used more than the 3 -ram that came free with my hs2 when new, indeed those are now more often used for backup in the computer rather than time shifting on the recorder.
