which bracket is this?
Discussion in 'Home Cinema Buying & Building' started by mickey, Jun 11, 2009.
  1. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    Hi guys , had an lg 42pc1d for a few years on the wall with this bracket. now i want to use it for my lg 50ps8000 but i am not 100% sure bracket will take it, i have seen that most brackets like this are up to 75kg limit, ps8000 is 75.6kg so should be ok but would love to be sure, positive i got it from one of the places here about 3-4 years ago. but cant be sure So Anyone know which bracket this is?. Cheers MIke
  2. Member 318509
    Member 318509
    Oct 29, 2008
    471
    London
    +41
    I'm not sure what bracket it is, but i do believe your TV is nearer 40 Kg ?
    yours
    dekodave
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,345
    +1,218
  4. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    Hi guys thanks, yes you are both correct, i read the 75.6lbs as kg:rolleyes:. teach me not to concentrate when im reading, bracket wil do it fine. thanks just have to get the right bolts. Thanks again Mike
