Which Bose surround to buy
Discussion in 'Home Cinema Speakers' started by jimmymleeds, Sep 13, 2017.
Tags:
  1. jimmymleeds
    jimmymleeds
    Mar 29, 2014
    9
    Leeds
    Hello all, first and foremost thanks for reading my question.
    I have a pioneer 7.1 hifi with two Bose 301's and a cheap eltax subwoofer. With limited space I'd like to get rid of the sub and swap it out for a Bose sub with the satellite speakers so I have a surround sound.
    Can anyone suggest which model I would be best buying so that I can have a 5.1 surround with the satellites, a Bose centre speaker and the 301's as my L/R fronts and the Bose sub. Many thanks
  2. PSM1
    PSM1
    Dec 20, 2008
    26,162
    +5,350
    A Bose sub is not really a sub and really just fills the mids in due to the small size of the speakers. They are overpriced and underperform in general too. I think most of the advice on here would be to not go down the Bose route. If you wanted small speakers then an AVR with sub/satellite speaker system will do the job for less money and most likely sound better too.
  3. jimmymleeds
    jimmymleeds
    Mar 29, 2014
    9
    Leeds
    Thankyou for your reply! So something along the lines of a B&W or Kef system ? Anything you can recommend? To be fair I have heard a setup that matches what I want with the 301s two satellites and the acoustimass and I was fairly impressed however if I can get better for cheaper then I'd happily take on any recommendations. Thankyou
  4. PSM1
    PSM1
    Dec 20, 2008
    26,162
    +5,350
    I have always liked the b&w m1s but you could also look at the monitor audio radius range. As for a sub I would look at bk electronics for value for money.
  5. jimmymleeds
    jimmymleeds
    Mar 29, 2014
    9
    Leeds
    Thankyou PSM1 I will check them out
