Which blank cd-r media? - Moved
Discussion in 'Desktop & Laptop Computers Forum' started by tspencerj, Jul 26, 2004.
  1. tspencerj
    tspencerj
    Oct 29, 2003
    23
    I think my cd writer 'drive not ready/empty' glitch is because my cd writer doesn't like my philips discs, although i read a good review on them which said that they played on most players. Other cd-r discs play fine on my cd writer. Can anyone recommend a good brand of cd-r disc and relay to me some of their burning experiences. Thanks.
  2. w3dal
    w3dal
    Aug 4, 2002
    4,935
    Chelmsford, Essex
    +548
    Hi Mate,
    What copying software are you using at the moment and what is your Burner?
    I have used Hundreds of Verbatim CDR's and have never had a problem with them. I use NERO 6 to copying my music onto a CDR.
    You can download a trail version from www.nero.com might be worth looking at.
    Also have you tried burning at a slower speed and also making sure you close the session on the disc not keeping it open??
    Dal
  3. tspencerj
    tspencerj
    Oct 29, 2003
    23
    Thanks very much for that. I have Adaptec Easy CD4 and Direct CD, all which came with the Freecom writer. Also, just bought an OEM suite 1 of Nero from E-bay. Both work ok with some Imation discs that I have, but intermitently with my Philips discs. I tried to buy some Freecom discs, as recommended by them, but can't find them anywhere.
  4. w3dal
    w3dal
    Aug 4, 2002
    4,935
    Chelmsford, Essex
    +548
    I think you can but Freecom media from Argos - well they used to sell you drives.
    Check www.svp.co.uk they have a great selection of media and have the verbatim ones i was telling you about.
    I would use NERO over adaptec easy cd any day of the week.
    Imation i have never been a fan of for music, there fine for data.
    TDK also do good CDR's
    I would give the Phillips discs a miss, if your drive doesnt like them they put it down to being a fussy drive.
    I just hope you didnt buy a job lot of the Phillips discs otherwise this could be quite an expensive test for you.
  5. tspencerj
    tspencerj
    Oct 29, 2003
    23
    cheers for that great advice. i'm very new to cd-burning and i didn't realise how much there was to know.
  6. w3dal
    w3dal
    Aug 4, 2002
    4,935
    Chelmsford, Essex
    +548
    No Worries Fella, we have all been there. Once you have a found a reliable brand of disc stick with it.
    Always takes a while to get whats best for you and your burner. Not eveyone is the same. Its the same for DVD-R media and DVD Burners
    Post back and let us know how u get on!!
    Dal
