MMachine78
Hi all,
I have finally got the go ahead to get a new subwoofer to replace my Rel T-Zero.
My room is 13ft x 14ft and I sit straight on to my tv...the only place I can have my subwoofer is to the side of my TV in front of the radiator as per pic....I have it on a sub isolation plate and downfiring, we had complaints on my previous subwoofer (q acoustics on the other side of the room). Since I have had the new one it’s been fine but maybe because it doesn’t have the same boom.
So now looking for another downfiring subwoofer, narrowed it down to either a BK P12-300SB-DF or a XLS-200DF.
The XLS will for better on the isolation plate which is 380 x 380 but if for the size of the room the P12 would be better then I can always accomadate that too by getting another isolation plate. The P12 is 400 x 400 but it might fit looking at the leg placement.
Any advice would be great...my max budget is £400 so I would consider something else downfiring that would sit on my isolation plate but not seen anything better than a BK.
