Which Basic 28inch50htz widescreen TV.
Discussion in 'Televisions' started by darksun, Oct 5, 2003.
  1. darksun
    darksun
    I want to buy a new TV. I was thinking about buying a Panasonic 28 inch widescreen, as I have seen one for around £400. I don’t need any special features only a great picture trough rgb. Any opinions.
  2. EniGmi
    EniGmi
    Oct 5, 2003
    Ive also started looking for a 28" widescreen and found that every tv seems to have its own +ve's and -ve's. I suggest seeing the TV working at a store as well before getting it.
    I did like the look of the Panasonic TX28PS12C however that is a 100Hz TV - its about £450 at Robertsons online. Sony tv's always seem to be a safe bet as well but they're also a bit more expensive than other manufacturers.
    I also found some good tv prices around but i havent purchased anything from any of these sites yet so i dont know how good they are:
    http://www.robertsons-online.co.uk
    (seems about £50-£100 cheaper than elsewhere and ive read some good reviews about them)
    http://www.internettvsdirect.co.uk
    (doing a 5yr warranty deal)
    http://www.empiredirect.co.uk
    http://www.unbeatable.co.uk
