Which AV-Amp
Discussion in 'AV Receivers & Amplifiers' started by HUMA, Dec 15, 2002.
  1. HUMA
    HUMA
    Hey,
    does anyone have test reports or experience with the following AV amps:
    Yamaha DSP-AZ2
    Denon AVR 3803
    Pioneer VSX-D 2011
    Which one would you recommend?
    Thanks for some informations...
  2. themmings
    themmings
    Nov 21, 2002
    382
    Northampton
    +4
    HUMA: the Pioneer has just been reviewed in the latest issue of What Video and TV.
    I think this mag has just changed its name to something widescreen. But check it out in your local newsagent and you should find it.
    You should also find plenty of info on this board on all 3 amps if you do a search.
    Tim
  3. malariaboy
    malariaboy
    Dec 16, 2002
    1,897
    taunton somerset
    +120
    the pioneer is very good m8 just got one myself and was well impressed
