Which AV amp with Triangle Antal ES
Discussion in 'AV Receivers & Amplifiers' started by SRam, Sep 21, 2004.
  1. SRam
    SRam
    Which amp would you recomend for 50/50 hifi HC?
    I was thinking Denon 3805 or NAD T753
    Other ideas?
    Tks for your advice
  2. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,257
    2
    +3,790
    The Denon would be my choice. Fabulous speakers by the way :).
  3. endora
    endora
    Jul 6, 2004
    261
    Of course, they are French ;) .....just teasing! :)
  4. SRam
    SRam
    Does someone have some listening notes about this two brands? I'll still have to test them both so what should I listen for?
  5. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,257
    2
    +3,790
    So is Micromega and they blow :p :laugh:
  6. endora
    endora
    Jul 6, 2004
    261
    Doh! :laugh:
  7. Ed Selley
    Ed Selley
    AVF Reviewer
    Jun 26, 2003
    11,257
    2
    +3,790
    Sorry SRam I've been a bit slack. The Denon makes more sense to me because having heard these speakers before (only in stereo however), the slight warmth of the Denon should take the edge off the Triangles tendancy to be slightly harsh with poor recordings. The NAD also offers this but at the expense of the Denon's mighty spec- I simply don't think it sounds good enough to explain away the short spec.
  8. ethan
    ethan
    Feb 18, 2005
    3
    triangle the best go with audio analogue, also nad and musical fidelity.
