Which AV amp for B&W DM602 S3, 600 S3, LCR 60 S3
Discussion in 'AV Receivers & Amplifiers' started by WSH, Sep 8, 2005.
  1. WSH
    WSH
    Apr 13, 2002
    997
    28
    +39
    I'm going to get a plasma, AV amp and surround speakers. I've my eye on the B&W DM602 S3, B&W LCR60 S3 centre and DM600 S3 for the rear. I was wondering which amp is recommended I should pair them to. I want to spend in the region of £200 to £250 and would consider 2nd hand if needs be.
  2. WSH
    WSH
    Apr 13, 2002
    997
    28
    +39
    Anyone?
  3. Weidass
    Weidass
    Jan 5, 2005
    104
    Cambridgeshire
    for that price u wont get anythign decent that is new. if you like a bright sound the go for a denon.
  4. WSH
    WSH
    Apr 13, 2002
    997
    28
    +39
    How much should I look at spending?
  5. mutley
    mutley
    Jul 28, 2002
    445
    Portugal
    I think Pioneer makes a killer combination with those speakers in Home Cinema.
    Ax2 or at least 1015 should be on your list.
    You should try also to get the LCR600 if you can. It's a major improvement over the LRC60, and the most important speaker in Home Cinema (IMHO).
    I have 602 with LCR600 and it's amazing. I had it with a Pioneer 2011 and it was a killer in HC.
  6. alphabet
    alphabet
    There is also the Cambridge Audio 540R for £250. Good in HT and excellent in stereo.
  7. Deanooo
    Deanooo
    Can I add one suggestion.
    That you make sure the Amp has Lip Sync correction as a feature as the last thing you want too do is buy it all and find you have Lip sync issues.
