Which audio player?
Discussion in 'Headphones, Earphones & Portable Music' started by fredsie, Jun 11, 2008.
  1. fredsie
    fredsie
    Nov 10, 2006
    1,227
    Liverpool
    +108
    I'm looking for a player with a specific set of characteristics:
    - simple file transfer (i.e. something that just appears as a drive when plugged into the USB port, no drivers or special software, and I can just drag and drop files onto it)
    - ability to play Ogg Vorbis format
    - capacity not less than a couple of gig
    - reliable
    - reasonable sound quality
    Things it doesn't need to do: :D
    - have a fancy coloured display
    - show pictures, video, tell jokes.
    Any thoughts?
    Thanks!
  2. fredsie
    fredsie
    Nov 10, 2006
    1,227
    Liverpool
    +108
    Guess there aren't any then! :D
  3. r@mside
    [email protected]
    May 29, 2006
    254
    28
    +25
    iAudio 7 comes in 4, 8 & 16GB flavours - does all you ask.
    Has a small screen, so it's hardly worth watching video on it.
  4. fredsie
    fredsie
    Nov 10, 2006
    1,227
    Liverpool
    +108
    Thanks, I'll look them up. :thumbsup:
