Which audio for zoomplayer?
Discussion in 'Desktop & Laptop Computers Forum' started by ilkand, May 10, 2003.
  1. ilkand
    ilkand
    Feb 9, 2002
    404
    +3
    I have Windvd which will do 7.1 analogue. When I try to use windvd as the audio in Zoomplayer, however, the maximum it will allow me is 5.1. What other audio codecs(?) are there that I can use to get 7.1 with zoomplayer?
    Cheers,
    Andy
  2. Threadkiller
    Threadkiller
    Aug 23, 2002
    63
    silly question but do you have a 7.1 setup? does your soundcard do 7.1 and do the disks you watch have Ex? I use a Fortissimo III and unless I use analogue outputs, it won't give anything but 5.1.
  3. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,180
    UK.
    +2,721
    If you use the spdiff output, and you can get it working via zoom, then you can get 5.1 and 6.1 no problem. That's how I have mine set up anyway.
    Gary.
  4. ilkand
    ilkand
    Feb 9, 2002
    404
    +3
    Thanks for your answers.
    I don't have a 7.1 amp, only a 5.1, that is why I was using the analogue outs to experiment with 7.1. I have a revo card which does 7.1, and using windvd it sounds pretty good. It won't feign 7.1 from a 5.1 source like some amps do, but on stuff like blade 2 it is quite impressive. I then switched to zoomplayer to use ffdshow and reclock to get that extra bit of picture quality people suggest, but when using the windvd audio decoder with zoomplayer, it will only do 5.1, not 7.1. At least there is only the option to use up to 6 speakers in the filter dialogue. Just wondered if there was another decoder for the audio side that I could buy to do 7.1 and keep the video side of things using cinemaster. I tried ac3filter which is very good, but limited to 5.1. Good quality though.
    I seem to be the only one using analogue outputs.
    Will have to bite the bullet and buy a 7.1 amp I think.
    Cheers,
    Andy
  5. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    I'm using analogue outputs, but am not using Zoomplayer (though was thinking of having a play). Currently using WinDVD straight. I'm using an MAudio Delta 410, so similar setup to you.
  6. ilkand
    ilkand
    Feb 9, 2002
    404
    +3
    The newest version of zoomplayer (just come out) has a new feature for Windvd audio (audio processor) which gives 7.1. Not sure if it is feigning 7.1 though or if it is DD EX. Hard to tell. I am still playing. Zoomplayer is vey good I think. Worth a try. Good fun.
    Andy
