Which ATI's have no fan?
Discussion in 'Desktop & Laptop Computers Forum' started by Mr. Wilby, Jul 6, 2003.
  1. Mr. Wilby
    Mr. Wilby
    Dec 15, 2002
    636
    +16
    My HTPC ATI 7500 DVI port gave up the ghost at the weekend. Works okay via s-video (not tried VGA) but I need DVI for 1:1 mapping on my Yam LPX 500.
    I'm currently using a fan'd 9500 Pro in there and its definitely a fair bit more noisy.
    I'm completely confused with ATI's new numbering policy. As far as I know, the ATI 9000 didn't used to have a fan and is DirectX 8.1 compliant(?).
    At my local PC store they have
    7500
    9000 LE
    9000 Pro
    9100 LE
    9200
    Any ideas which ones have fans and also whether the 9200 is just an updated 8500 or something?
    TIA
  2. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    The Saphire 9600 is fanless. You can also rip the heat sink and fan off the 9500 pro and replace it with a passive Zalman heatsink.
  3. Mr. Wilby
    Mr. Wilby
    Dec 15, 2002
    636
    +16
    Hello Jeff. Thanks for the reply. Not sure yet (just posted in LMP forum) whether my LMP case will fit a zalman. I don't think there's enough room for it ...
    9600 might be the way to go.
  4. nfordenfield
    nfordenfield
    Apr 9, 2001
    625
    19
    Kent
    I've seem pics of the LMP with zalman modded 9500, so should work.
  5. ilkand
    ilkand
    Feb 9, 2002
    393
    +3
    I have the 9500 (64mb) which does have a fan, but the noise is not that bad at all. See if you can have a listen to one working. My super duper Zalman (expensive) CPU cooler makes enough noise to drown it out.
    OOOOPS missed a bit of your initial thread, sorry. Perhaps the PRO sounds louder or we have different standards.
  6. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    My 9500 is playing up and would be under warranty but I took the fan off and replaced it with a Zalman HP so I'll probably be out of luck. It will be a couple of weeks away anyway so I need a new one.
    Jeff, can you confirm that you mean the 9600 128mb non pro sapphire, Kustom pcs have the connect 3d 9600 128mb non pro and show it as passivly cooled but I have just asked for confirmation from The Overclocking Store before I order one and they say it has a fan??
  7. Jeff
    Jeff
    Jul 13, 2000
    5,489
    Basingstoke
    +256
    John,
    I saw a picture of one in PC Pro and it was fan-less. There might be different variants out there.
  8. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Hmmm thanks Jeff, looks like we need to check each one with the supplier.
  9. Mr. Wilby
    Mr. Wilby
    Dec 15, 2002
    636
    +16
    The image on kustom pc's definitely has no fan... TOS is about ten quid cheaper though... Hmm...
  10. Mr. Wilby
    Mr. Wilby
    Dec 15, 2002
    636
    +16
    Would something like this be enough to cool a 9600 Pro given that its 0.13 micron and supposedly generates less heat that the older 0.15 micron 9500's?
    Given that a 9600 (non-Pro) can run with just a HS then I'd think it might be an option?
    Very tempted as I'm pretty sure my Abit NF7-S can't fit a Zalman heatpipe inside the LMP case... but I have one of these other Zalman coolers from my now defunct 7500...
  11. JohnS
    JohnS
    Oct 31, 2000
    2,580
    71
    Herne Bay, Kent
    +33
    Thats why I emailed TOS this morning to confirm but ll they said was "This card is not passively cooled, however we do stock alternative passive heatsinks that will fit this card"
  12. Mr. Wilby
    Mr. Wilby
    Dec 15, 2002
    636
    +16
    In the end I opted for a cheap powercolour (64mb) 7500 from overclockers.co.uk.
    It has no fan and I personally can't tell any difference in PQ between this and my 9500 Pro. I'm using overlay however (rather than that new fancy thing I forget the name of).
