which apm for these speaks
Discussion in 'AV Receivers & Amplifiers' started by joel112, Jul 2, 2003.
  1. joel112
    joel112
    Mordaunt Short:302 Satellite Speakers - Cherry £119.90
    Mordaunt Short:905 Centre Speaker - Cherry £119.90
    Mordaunt Short:907W Subwoofer - Cherry £219.90
    Mordaunt Short:912 Bookshelf Speakers - Cherry £199.90
    what amp for ~300 for these would work well with em...
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,982
    Berkshire
    +111
    Any of the new budget amps from Sony, Yamaha, Denon, Marantz, etc.
    The MS cherry finish is a lot harder to drive than the normal black finish 'tho. No, just kidding. :clown: Those are nice speakers. :cool:
  3. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    Be wary of the impedence of these speakers.
    The 302 for example are 4ohm's.
    The pioneer you ask about in another post is 8 ohm's only and would not be compatable with the above.
    Regards, Mylo.
  4. joel112
    joel112
    yeh, i noticed, thats why i posted here to try and match summat up... dont wanna spend a fortune tho
  5. joel112
    joel112
    actually on the mordunt short site it says all the speakers are 4-8 ohms... so it might be ok
  6. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    The pioneer is 8 ohm or above. I have a Pioneer VSX-D710s and the specs are similar. If the speakers dip to 4ohms it could cause the amp to over load. I have not tried 4 ohms on mine by the way.
    Regards, Mylo
