Which amps have 2 component video outputs?
Discussion in 'AV Receivers & Amplifiers' started by pingu, Sep 20, 2005.
  1. pingu
    pingu
    Nov 30, 2004
    440
    28
    Berkshire
    +28
    I'm looking for an amp that has 2 component outputs and video upconversion (from composite/S-vid to component).
    The reason is so that I can feed both my projector and LCD with component.
    For the PJ, I want to use 2 inputs so I can vary the settings: HDMI for DVDs (ambient light is low) and YUV for games and Sky (higher ambient lighting).
    With many amps, this leaves only S-video output for the LCD - I want to feed it YUV.
    I've seen from pictures that the new Denon AVR-3806 has 2 component monitor outs, but are there any others in a similar or lower price bracket?
    Cheers,
    pingu.
  2. Benrudd1
    Benrudd1
    Jan 19, 2003
    961
    Pembroke Dock
    +66
    I'm not sure about any receivers with 2 outputs. However have you seen this.
    It takes a single component feed and splits it into 2 outputs with apparently no drop in quality.
    Hope this helps :)
  3. pingu
    pingu
    Nov 30, 2004
    440
    28
    Berkshire
    +28
    Aaah.... that would do it :smashin:
    Thanks Benrudd!
