Which Amp?
Discussion in 'AV Receivers & Amplifiers' started by GJC, Oct 16, 2003.
  1. GJC
    GJC
    Mar 1, 2002
    2,094
    London
    +65
    I am considering buying either:
    Denon 1804 - £349.99 (0.08)
    Yamaha 640 - £399 (lower distortion than Denon 0.06)
    or
    Nad T742 - £399 (amp has good headroom, even though its 50w, 2 channel is good too)
    I would say that the system will be 70/30 music based
    The amp will partner B&W 601s3 fronts, 60c, VM1 rears (£700ish)
    ASW 675 sub or Vel. SPL 1000. (£650 - 900)
    What do you guys think, should I consider any alternatives?
    My room is about 4m x 10m.
    Budget is around £1700
    Regards,
    GJC
