which amp?
Discussion in 'AV Receivers & Amplifiers' started by joel112, Jun 22, 2003.
  1. joel112
    joel112
    i have been looking for a new amp.. and so far found
    Yamaha DSPAX630
    Sherwood RD8108
    Pioneer VSX-D811
    but i am unsure what to go for, it is probably be ging to be used with mordaunt short seakers and sub...
    anyone got these amps, or reccomend another for a max of £350?
  2. bunkerbuster2
    bunkerbuster2
    You have to demo them mate.
    You'd be hard pressed to demo them all in the same surroundings though (Sherwood are exclusive to RS)
  3. nathan_silly
    nathan_silly
    Drop the Sherwood from the list, IMO very poor quality. The other two are much much better.
  4. bunkerbuster2
    bunkerbuster2
    i would have posted those exact words...but the RS fanboys in this forum would have been outraged.
    Sherwood = Big baggy pants IMO
  5. wilber
    wilber
    Sep 29, 2002
    1,970
    +30
    I owned a 630 & loved everything apart from it being poor with music (but they all are) and it was black, so had to go. Got a Pioneer 811 and it matches the yamaha in the movie department but is possibly even worse with music (so I don't use it for music), hoever it does look good with the rest of my gear.
    Either amp will probably be just dandy. The yamaha can be found cheaper - if you can find it. The pioneer is hard to get significant discounts on 'cos it's really popular
  6. hindutimes
    hindutimes
    Add an extra of 50quid to your budget to go for Pioneer 912.
    For £400 you've got auto MCACC, 100Wx6channels, and with the latest surround sound formats
  7. joel112
    joel112
  8. Big Adam
    Big Adam
    May 7, 2003
    509
    Peterborough
    +4
    Have you considered the Yammy 440?
    Supposed to be slightly better musically than the 630.
    Big A
  9. gingerone
    gingerone
    Dec 10, 2002
    2,415
    +302
    I'm going to purchase the Yammy 440 pretty soon, looks like a winner.
  10. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    Marantz 5300 is supposed to be better than the Yammy for music, I have this amp and to me it sounds great with both movies and music
  11. bob69
    bob69
    Just bought an RX-V440RDS after reading the What Hifi? review and have been completely blown away with the sound quality for both music and movies, although I mainly use it for DVD's and Xbox!:zonked:
