which amp?
Discussion in 'AV Receivers & Amplifiers' started by jordy, May 6, 2002.
  1. jordy
    jordy
    which should i go for the marantz sr4200 or denon avr1602
    i will be using mission fs2-av flap panels.
  2. s9s
    s9s
    jordy
    I think you will find that any sr4200 owners (like me) will tell the amp is a steal, you'd be hard put to find the features and quality of the sr4200 at the prices you can find them (mine was £256 form RS over the net).
