which amp?
Discussion in 'AV Receivers & Amplifiers' started by monkeyboy69, Dec 29, 2003.
  1. monkeyboy69
    monkeyboy69
    Mar 30, 2002
    589
    +11
    currently looking at upgrading both speakers and amp and I'm currently looking at the b+w 700 series. I was going to put a denon 3803 with them but some are saying the 3803 won't be powerful enough to drive the b+w to their fullest potential. Looking at the denon spec sheet it says " the AVR-3803 boasts high output power of 110 W for each of the 7 channels. "
    So my question is will it be powerful enough for the 700 series and also if it isn't what do I have to look at to determine whether an amp is powerful enough. is it the amp wattage or is it something on the speaker spec sheet I shoudl look at.
    any help would be appreciated
    cheers
