which amp to run my sub?????????????
Discussion in 'ICE, Sat Navs & Dash Cams Forum' started by Carter, Sep 21, 2005.
  1. Carter
    Carter
    Hi im just in the process of buying my first sub and im currently looking at some sub & amp packages on the net. I have a pair of vibe qb69's running off a pioneer gm5100t 2 channel 750W amp.
    I thought that it would be best to run the sub off a seperate amp but i was told i could run it off my current amp with my speakers. Would this be best or would it be best to buy a seperate amp?
    Could you recommend any decent sub & amp packages or just subs if needed I have a budget of about £200.
    Many thanks
