which amp to go for with av9 dvd 29 p7 or parasound a51
voice x
I have recentley purchased arcam FmJ AV9 and dvd29 and looking for a good power amp to be used for av & 2 channel use and be dynamic all round
the speaker pakage is bmw802 fronts and 804 as rears the 2 amps i am looking at are :lease:
1) Arcam P7
2) Parasound A51 amp
ANY OTHER SUGESTIONS WILL BE APPRECIATED:lesson:
NonPayingMember
Previously Liam @ Prog AV
Second Crustys recommendation, but of the two listed I would go A51 over P7 with those speakers.
thatMikeguy
Crusty,
Interesting to see you plug the Brystons. Is there a reason? I have a good angle on their five channel unit and was holding back as I didn't think it was a good fit with my Arcam kit. Is the five channel up to snuff? As my signature says I am running Sonus Faber speakers and they have a single terminal :rolleyes:
M.
Kenny Glasgow
the P7 sounds very good with the AV9 and is obviously the best visual match.
I would agree that Bryston amps are superb and as you live in Canada why don't you give them a try?
I don't think that you'll have any probs with your SF speakers (which are great)
Barend
I'm quite happy with the P7 I recently bought.
No compression at orchestral tutti as with the AVR300 I previously owned, and a very sweet sound (even at late night listening levels) in i.c.w. the AV8.
Now I have an angle on a very cheap s/h Linn set: Chakra 5 ch final (5 x 60W @ 8 ohms) and Unidisk SC player/pre combination.
If that works out it will be fun to compare the P7 to the Chakra.
