which amp of 3?
Discussion in 'AV Receivers & Amplifiers' started by maamtoamd, Jan 20, 2002.
  1. maamtoamd
    maamtoamd
    hi i'm buying an amp to go with ...
    tv.. tosh 28w93b
    dvd pioneer 444
    mission fs2av speakers
    should i get 1)pioneer vsx c 300 rds £250
    2)yamaha ax620 £290
    3)yamaha rsx 800 rds £370
    any suggestions would be nice :)
    (im swaying towards the 800 though)
  2. GarethRamsay
    GarethRamsay
    Jan 13, 2002
    Don't know about the other two, however I can recommend the Yamaha. I have the RSX version - it was only £9 more - and have never been happier with a piece of kit ;)
    Gareth
  3. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Although I couldn't possibly recommend the Yamaha AX620 more, no one on this forum can or has a right to tell you what to buy. The only person who can decide which amp is best for you, is yourself. If you think you've narrowed yourself down to these three then try your hardest to get demo's of all of them, in as similar cirmcumstances as possible to those in which you will be using the equipment. In your own home if at all possible.
    Only then will you know which amp to buy.
  4. maamtoamd
    maamtoamd
    i see your point
    i thought the ax620 would be good after reading reviews etc
    but then i saw the rxs800(also excellent reviews) which seems more future-proof if there is such a thing and excellent value for money.
    see im not the type of chap to chase trends and upgrade for the sake of it.i justy want to get a half decent setup that i can live happily with for a good few years.
    only problem with getting a demo is that i think the rsx 800 has just been discontinued so there arnt that many about ...anyway enuff rambling from me
    i think i'll get one of the yamahas as i know nothing bout the vsx c 300,i suppose ya gets what ya pay fer in the end
    thanks for the replies btw
    cheers :)
