Which Amp can I buy
Discussion in 'AV Receivers & Amplifiers' started by commando850, Feb 9, 2002.
  1. commando850
    commando850
    I want to buy an Amp but I can't seem to find one that fits my requirements. i want an amp that has a built in dolby digital 5.1 decoder as my DVD hasn't got one, a built in radio, but most important of all it must only be 100mm high so it can fit in my cabinet an ideas without breaking the bank anyone
  2. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    If you've been looking specifically for amp's, then you'll never find what you want. What you are looking for is an AV Receiver, which is an amp with an inbuilt radio tuner.
    But 100mm high? 10cm? Are you serious? You've got very, very little chance, unless you're willing to shell out for something like the Sony HTK215 or HTSL7A, which really aren't worth the money.
  3. alextgreen
    alextgreen
    Apr 17, 2001
    550
    London
    +5
    a small amp is what, 13-14cm high? It is worth making room for a bigger one.
    One more things, AV recievers get HOT. They need breathing room all around. You shove it in a space with a VCR and DVD deck, and it's meltdown time.
  4. philmate
    philmate
    Nov 6, 2000
    217
    Southend-on-sea
    +4
    Extra expense I know but change the cabinet and hey you could choose virtually any amp on the market depending on your budget , it''ll make sense in the long run.
    Philmate.
