which amp and speakers? (first post here - be gentle!)
Discussion in 'AV Receivers & Amplifiers' started by pobs, Oct 31, 2001.
  1. pobs
    pobs
    ok guys, your expert knowlege would be greatly appreciated.
    i have a sony dvd (DVP-s725d) and want to hook up and amp and speakers for about £500-800. the dvd has 5.1 output.
    what should i get and where should i go to get it? ( the blokes at richer sounds didn't seem to be that knowlegeable)
    Remember, be nice, its my first post here
    :clown:
  2. bob007
    bob007
    Here`s a start for you: http://www.richersounds.com/cgi-bin/search.cgi?load=frame This site can offer you some really good deals.
    Yamaha have been selling very good budget/mid range amps for sometime and know what they are doing. http://www.yamaha-audio.co.uk/yamaha_home_cinema/home_cinema.asp
    Mission are also very good,http://www.mission.co.uk/main.htm have a look on their site then go to richersounds for a bargin price failing that goto http://uk.pricerunner.com/Tree.jsp?main=15
    To get reviews click on AV INFO <<< then hardware reviews.
    At the moment r/s are doing the yamaha DSPAX620 for £299
    and the RXV620(RDS) for £315 both very good amps. That leaves you approx £500 for speakers/cables.
    I`m sure you will get more helpfull advice if you stick around.
    good luck, watch out for the bug.
    :rolleyes:
    P.S Richersounds are ok if YOU know what you want
  3. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    Try the Denon AVR 1602 for £349.99, which leaves you around £4-500 for your speakers. The only ones I have used in this area are by Quadral, I forget which model, but they are £560.
    Otherwise you may want to try a Mordaunt Short Premier system (£500 for RS) or the Polk RM 6000 for £500 from Polk dealrs such as myself.
    Hope this helps!
  4. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    I would also rekon a entry level Denon or Yamaha amp plus a nice speaker package like e.g. Tannoy M(x) series.
    This should fit the budget well and you can upgrade from there at a later time (e.g. add a subwoofer).
  5. kirk grubb
    kirk grubb
    Sep 6, 2001
    586
    +11
    i would reccomend the kef speaker package from sound and vision at £500. (80 centre,2pair 60s and 30b sub, did retail at over £1000. and would go for the best dennon amp you can afford. could you help me now please.. i wish to ask my own questions in the forum but being a newbie to computers i cant find the right area to submit my questions. hope you can push me in the right area, kind regards ... kirk
  6. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    What kind of help do you need?
    Just call up the main page at www.avforums.com , click on the forum you wish to post your question and select "new thread" in the upper right corner.
  7. Iain Shields
    Iain Shields
    Oct 19, 2001
    787
    N.Ireland
    +3
    How about a Kenwood KRF-V5050D
    For the price ( I've seen it for £179 ) it's hard to beat... it got 4 and a half stars out of 5 in the Jun edition of Home Cinema Choice
  8. paiger
    paiger
    A Sony 940 or 1070 will match your player perfectly. You'll hear a lot of Denon and Yamaha fans on here and it's good kit but Sony AV recievers are under-rated. Go have a listen for yourself. As for speakers, I would recommend either the Tannoy MX series or Missions. Right in your price range and good value for money, particularly the Missions.
    Steve
  9. 9004
    9004
    For my money, you want pro-logic II for all the times you are watching anything other than DVD - so the Denon AVR1602 has to be top choice, or if you can find one the Marantz SR4200 at £299. (Denon's my choice). Speakers, check out the Mission M7 series, from £399 a set, or to be really budget 2 pairs of Denon SCM50 at £70 per pair, and a Mission M7 centre for £99, (you'll be suprised, I was) then add a sub later (Mission M7 coming soon @£249). BUT audition them first at a dealer with decent facilities, to see if you like it.
  10. pobs
    pobs
    have just listened to the KEF2005 speakers with the denon 1802 amp, are the worth it? (1300 including cable)
  11. flunchy
    flunchy
    I have the Kefs and love them, and all Denon amps are good buys. But £1300 is too much! You should be able to get this package for £1000-1100.
    1802 is £360 at http://www.hifibitz.co.uk/ and you can get the Kefs for much less than the £799 list price if you shop around (plenty of threads already on this forum about this).
  12. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    +59
    £1300 for the 1802 and KEF's including cable is a good deal, seeing as it would otherwise cost you around £1250 + cables.
    £1,250 may the best you can get from a good dealer.
