anlygi
I'm in the process of collecting components for my first build since 2004, yes you read that right! It was a Pentium 4 Northwood with Geforce 6800 so as you can imagine, I'm a bit out of the loop with components. The last and only AMD system I built was an Athlon XP in my teens. I've been using laptops for my computing needs with consoles for gaming this past 2 generations, but I want to go back to PC gaming as I miss RTS games and tinkering.
I think I've settled on a Ryzen 7 3700X or Ryzen 9 3900X, though I'm waiting to see what Zen 3 brings but think I'm more interested in a potential price drop on the two CPUs I mentioned to be honest. The plan for GPU is a Geforce 3070 which, checking online, should be ok without either bottlenecking it? Trouble is, when looking at motherboards there are so many AMD chipsets which I find confusing.
I've already picked up a 1TB Western Digital Blue SSD (SATA) for my system drive initially, but plan to add a PCIe 4 NVMe drive later when they come down a bit in price and then use the WD as secondary storage. From what I've read, either B550 or X570 will meet my needs? So what's the difference between the 2? I read the B550 boards are AMD's response to demand for lower cost PCIe 4 motherboards? They seem to be at their RRP whilst X570 have dropped so the difference could be as little as £20 depending on my choice of motherboard. I've been looking at boards like the MSI B550 Tomahawk. Budget is around £150 but don't mind paying more, though not £200+! I don't want to waste money on features I won't use however. I don't even have a professional need for wanting such a fast NVMe drive. Should I save money and go for something like the B450 Tomahawk, which I think will take a gen3 NVMe SSD? I thought about a future upgrade path but read Zen 3 will likely be the last on the AM4 socket which would mean a new motherboard anyway in 2 or 3 years.
I'm probably wrong about some things above, as I said, it's been a while!
Advice appreciated.
Advice appreciated.
