Which adjustable speaker brackets for M&K K4's
kev00
AS title.
Currently got my 2x pairs of k4's flush mounted, but want to put them on an adjustable wall mounted bracket so i can bring them away from the wall and angle them a little.
Would also like to utilise the existing mounting holes on the back of the k4's
Any recomendations? :lease:
Cheers,
Kev
Helicon
Unless you're in a very weird situation, you shouldn't need to angle them - being tripoles they will spread the sound more so than any other surround speaker. You may find it won't make much difference, but may have an adverse effect. M&K's prefer to be close to a wall as well.
30CenturyMan
M&K Tripoles are designed to be flush mounted to a wall or other surface, it helps them 'spread' their sound wider. :)
Amazon Fire TV Cube Gen 3 Review: Coming Soon
