Hi All
I was going to purchase a Acer 6930G which will be used for some gaming but have found two specs which are the same price. Which is the better for gaming ?
ProcessorIntel® Core 2 Duo (T6400 - 2.0GHz, 800MHz FSB, 2MB) Screen16" (HD 1366 x 768 resolution, high-brightness (220- cd/m2) Acer CineCrystal TFT LCD, 8 ms high-def response time, 16:9 aspect ratio) Operating SystemWindows Vista Home Premium Edition RAMHIGH (3072MB 3GB) Hard Drive250GB SATA Optical DriveBlu-Ray (Blu-Ray HD Play back + DVD-RW & CD-RW) GraphicsDedicated (NVIDIA® GeForce® 9300M GS with 256MB Dediacted RAM) Wireless LANWireless (WIFI LINK A,B,G,N Includes MIMO) Network Card10/100/1000 Gigabit Fast Ethernet Integrated WebcamYes (CrystalEye Webcam) Card Reader5-in-1 card reader (SD//MS/MS-Pro/MMC/xD-Picture card) USB Ports4x USB 2.0 Ports SpeakersDolby®5-certified surround sound system with two built-in stereo speakers and one subwoofer supporting low-frequency effects Modem56.6K Modem VGA Port1 External VGA Port Kensington LockKensington lock slot Charge Time2.0 Hours ExpressCardExpressCard/54 slot HDMI1 HDMI Connector Finger Print ReaderFingerprint Reader Battery Life2-3 Hours (This Specific Model 2.5-hours) Weight3-4 Kg (This Model 3.68kg) Warranty12 Months Acer Collect & Return
or
or
- AMD Turion X2 RM-72 dual core processor.
- 2.1GHz processor speed.
- 1Mb cache.
- 4GB RAM.
- 250GB hard drive.
- Multi format dual layer CD/DVD drive with DVD & Blu-Ray movie playback.
- 16in HD widescreen.
- Resolution 1366 x 768 pixels.
- ATI Mobility Radeon HD 3650 graphics display with 512MB VRAM graphics memory.
- 1 Ethernet port.
- Wireless/WiFi enabled - b/g/n.
- 4 USB ports.
- 1 HDMI port.
- 5 in 1 card reader (SD, MMC, MS, MS PRO, xD).
- Dolby sound system 2.0 (2 built-in speakers)
- Fingerprint reader.
- Integrated 0.3MP webcam.
- Microsoft Windows Vista Home Premium.
- Microsoft Works 8.5 software application.
- Preloaded with anti-virus security software with a minimum 30 trial.
- Preloaded by the manufacturer with a suite of applications which include: music, photo, movie, business, tuition and gaming software.
- Adobe Acrobat reader.
- Up to 3.3 hours battery life.
- Size (H)4.4, (W)38.5, (D)27.8cm.
- Weight 3.4kg.
