HungryGhost
Hi Everyone,
I currently have a 40" Sony KDL-40W4000 which, for the time was a pretty high end set, but it's nearly a decade old and I'd like to upgrade to something slightly larger with 4K/HDR support.
I'm looking for a 55"-ish 4K HDR set which will primarily be used for gaming and will connect to my PS4 Pro, Xbox One (no HRD/4k unfortunately), Switch and Wii U. It's not my main television and is just in my gaming man-cave so don't want to spend more than around £500-£750.
I literally haven't looked at televisions in ages so other than 55"-ish with 4K/HDR support I'm not really sure what I'm after. I'll probably hook up a 4K Chromecast for streaming movies and YouTube so I'm not really bothered about build in 'smart' apps or other features like that. I think mainly I just want something with a decent panel and reasonable speakers.
Any tips, suggestions and advice would be appreciated. Especially if you mainly use your TV for gaming.
