Which 5.1 set up to get
VanTasstic
Hi all, I'm looking for some advice on which 5.1 speakers to go for
I have a Sony STRDH800 amp and a Sony BDP-S350
Budget around £400-£600
The downside unfortunately is small and compact
So far i'm looking at the mordaunt short alumni, Kef 2005.3 or with a push the Kef 3005SE
Any other recommendations
PSM1
The Morduant Short speakers are rather 'bright' and may not be a good match to your sony amp which is also classed as 'bright'.
The kef speakers you mention should be fairly neutral but will tend to the bright side due to the style nature of them.
TAnnoy speakers are normally a goof match for Sony amps. Could look at the Tannoy sets based around the F1 speakers. Also the Q Accoustic 1010i set could be worth a listen.
