Which 42" plasma is best for a PC
Discussion in 'Plasma TVs Forum' started by SinisterRocket, Mar 26, 2003.
  1. SinisterRocket
    SinisterRocket
    Hi All,
    I am thinking about getting a plasma screen. I will be using it to connect my DVD, XBOX, Gamecube, SKY box and most importantly my PC. Which 42 " plasma is best for connecting a PC to it. If anybody have a setup where they use a Plasma Screen for playing PC games can they let me know how its is. Just the thought of playing Battlefield 1942 or Comanche 4 on a 42" screen is awsome. But not sure if they could do the job.
    Thanks SR
  2. philipb
    philipb
    Mar 6, 2002
    2,029
    63
    Swindon
    +148
    The best 42" screen for PC use is a 43" screen - the Pioneer 433MXE.
    Generally speaking go for higher resolution screens if you want good PC performance. There are plenty of others apart from the Pio, but that's what I have so I'm biassed. The advantage of the 433 which almost no other screen shares is the DVI input - uses the digital video out from your graphics card (if you have one, and most latest cards do).
