jjgreenwood
The wife wants a netbook. Something which has integrated 3g connection rather than having to use the dongle. I thought I'd be unindated with choices but it looks like these are few and far between. I want a good quality unit.
What is your budget?
sub £450
What size laptop do you want?
(In terms of screen size)
Netbooks are usually less than 11"
Ultraportable laptops are usually 11" to 13"
Standard laptops are usually 14" to 16"
Desktop Replacements are usually over 17"
below 13"
Do you have resolution requirements?
For example "must display 1080"
nope but higher the better
Do you want a matte or glossy (reflective) screen?
don't mind
What will you be using the laptop for?
For example, Browsing, Gaming, Word Processing, Video Editing, Web/Graphic Design
general net use and word processing/powerpoint
If you will be gaming, what games do you need to play?
not required
How long does the battery need to last?
longer the better - fairly important
Does it need to be portable?
Will you be taking it out and about or just leaving it at home on a desk
yes this is essential
Do you require Blu-Ray?
no
Do you require HDMI output?
no
Do you have a preferred brand?
For example Dell, HP, Acer
dell and apple, but neither fit price/3g requirements
Are there brands you would prefer to avoid?
anything too cheap & tacky
Would you be happy with a refurbished laptop?
prefer new
Any other details you feel necessary... Colour; Webcam; Good quality speakers; general spec: CPU, RAM, HDD space, SSD; Operating System or anything else you can think of.
prefer it to have win 7 but will consider andriod
sub £450
below 13"
don't mind
not required
no
no
prefer new
