which 37" plasma?
Discussion in 'Plasma TVs' started by chris_huh, Apr 5, 2005.
  1. chris_huh
    chris_huh
    Mar 28, 2004
    73
    London
    I am looking at getting a new tv as my last one broke and i was able to get a refund from comet.
    I can't go any larger that a 37 incher, and was looking at maybe getting a plasma or lcd. First question is, are there any HD compatible 37" tv's out there or will there be one soon. I don't want to spend too much as the refund was only about 1500 and dont want to go much higher than that.
    I was looking at the Panasonic Viera TH37PE50 or something like that.
    As i already had a nice set up with my last tv i am rather set on what connections i need as i have a dvd hard drive recorder, a pace twin freeview box, a vcr, xbox and ps2 to fit into the connections. On my last tv i had three scarts and a component in, and fitted them all in nicely.
    Any suggestions?
  2. Anthall
    Anthall
    Oct 27, 2004
    219
    Kettering
    +4
    I personaly think the 37" viera would do you a treat for
    your connections. But it is not HD ready.
    I still went for the Viera and am more than happy.
    Will consider the HD content when it's out and running
    and people are happy with it.
    The decision is yours.
  3. chris_huh
    chris_huh
    Mar 28, 2004
    73
    London
    yeah, maybe i will just go witht he Viera, looks damn good. Even if its not hd ready it wil still be a good buy.
  4. hao
    hao
    Had mine since Xmas and wouldn't swap it. Good PQ.
  5. DAS
    DAS
    Feb 7, 2005
    61
    London
    Hear hear.
    Had my Viera for a few weeks. Passed the 200 hours mark the other day and depite not really understanding the DVE disc, managed to get an even better picture (to my untrained eyes). I think it's a wonderful piece of kit.
  6. jimg
    jimg
    Jul 4, 2004
    826
    +58
    Wander over to the LCD forum and check out the HD ready 37" screens. It will be 1366x768, be HD ready and cround your budget. LCd's are the way forward!
  7. superpixel
    superpixel
    The forthcoming Panasonic 37PV500 is a hi-def plasma, HD-ready, and should be just £200-£300 outside your budget.
    The 37PE50 will be just fine for SD sources IMHO though, and touts better brightness spec, but doesn't look as good in the flesh as the Panasonic photoshoots and the PV500's are designed to be more stylish as well.
    Either would be a good choice PQ wise.
    The LCDs aren't up to scratch in my opinion, but we all have different ideas.
    Edit: I know you said 37" is your limit, but price difference isn't big (£100 difference between 37" and 42" on the Panasonic online pricelist...) if that was your limiting factor
