WHICH 37" PLASMA
Discussion in 'Plasma TVs Forum' started by AIKIDOSAM, Aug 27, 2004.
  1. AIKIDOSAM
    AIKIDOSAM
    Hello Everybody In Plasma Land.i Am Saving Up For A Plasma For Xmass Cant Make Mind Up Which Shall I Buy Budget Will Be £2500.which Will I Buy Wife Does Not Want 42" In The Livingroom.which One Shall I Buy
  2. RustyH
    RustyH
    If you are getting it xmas, then Im not sure there is much point thinking about it to much yet till all the new models come out. If your fingers get itchy and you want it now, then many people will tell you to get the PW6 and you will have £500 left for input boards, a nice tuner, etc.
  3. Bernard Barnett
    Bernard Barnett
    May 16, 2002
    671
    Norfolk
    +5
    There isn't a great deal of difference in the overall size between 37 and 42/43 inch models. But at 42/43 you will have much more choice. I suggest you go for a 42 and tell her it's 37.
  4. GrahamC
    GrahamC
    Jul 22, 2001
    2,259
    Morecambe, U.K.
    +67
    That's the stance taken by a lot of forum members, lie but it does have a high risk factor.. :rotfl:
  5. zedzed
    zedzed
    Jul 12, 2004
    821
    Linlithgow (nr. Edinburgh)
    +13
    If you already have surround sound/amp etc. then a 42" panel (plasma without speakers etc.) is the same length as a 37" with speakers! e.g. The 37" Viera is the same length as a Panasonic PW6! (that's the argument I used to convince the wife to go for a 42"!)
    ZZ
