Which 36" TV to buy
Discussion in 'General TV Discussions Forum' started by David A, Jul 16, 2002.
  1. David A
    David A
    I'm after reccomendations for a 36" TV. I've already got a yamaha dspx620 av amp, and all the surround speakers, a pioneer dv444 dvd player and SKY digital. Therefore the dobly digital/dts aren't wholly necessary from the TV.
    Also a cabinet isn't totally necessary as well as I have an AV bench/rack to put it on.
    Any reccomendations?
    Or to throw more ideas in the pot should I consider a rear projection??:confused: :confused:
    Thanks in advance
  2. Oblivion
    Oblivion
    Feb 23, 2002
    526
    Behind You
    Id go for the Toshiba 36ZD26P
    Nicam stero and Progressive Scan. A few of use have the 32 inch model and have yet to hear a bad thing about the set :D
    Paul
  3. beavis
    beavis
    I would have a look at one of the new Toshibas in a shop as the look is definitely personal taste..much like the picture frame tv's. Personally, I would go for the Philips 9607, looks the biz..and a lot less plastic!
  4. Adrian
    Adrian
    Jul 17, 2002
    12
    4
    West Sussex
    Philips 36 9607 has a Panasonic tube, this has been officially confirmed by Philips.
    Go for the Philips which has philips software and the exceptionally good Panasonic tube.
