Which 32" ???
Discussion in 'General TV Discussions Forum' started by stu1972, Oct 31, 2004.
  1. stu1972
    stu1972
    Just joined the forum and would appreciate it if anyone could give me some advise in purchasing a new set.
    Have been toying with buying a plasma but have decided to stick with CRT as screen quality is most important to me.
    I'm after a 32" preferably with component in. Which is currently the best one availible?
    Is pixel plus 2 just as good as progressive scan?
    Should i just forget about component in's????
    Have got my eye on Philips 32PW9509, anyone got one of these????
    Any help would be greatly appreciated...
    Stu :smashin:
  2. Londondecca
    Londondecca
    Dec 21, 2003
    2,080
    +96
    32" with component in? I would recommend the Toshiba 32ZP48 or maybe the new Panasonic PD50 - but I am not sure when this will be released.
    I have not tried the Philips but if you do a search, I am sure there will be a lot of threads
  3. red16v
    red16v
    Aug 20, 2004
    552
    +5
    I cannot recommend the Toshiba 32ZP48 highly enough. Regards, yt.
  4. ruddocg
    ruddocg
    Oct 20, 2004
    7
    3
    Leicester
    Hi I too am new and posted this thread on the Philips 32pw9618 or the 32pw9509
    http://www.avforums.com/forums/showthread.php?t=158210&highlight=32pw9618
    Both look good and although the 9618 is an older model seems to have more positive comments in other threads - better picture and sound, fewer problems reported and on paper has the same or better spec.
    So I decided to go for the 9618 which should be arriving, the link in the thread is also for the cheapest 9618 I could find £700 when I looked but now up to £780.
