which 32 widescreen
Discussion in 'General TV Discussions Forum' started by Kentish, Jul 13, 2002.
  1. Kentish
    Kentish
    Jun 15, 2002
    23
    OK here is the rub.
    I have to replace my 32" widescreen Daewoo (real flat tube) again as it has mega pincussion type screen.This is the second time its happened (first set lasted 4 days,this replacement 3 weeks).Laugh if you will,but the picture is absolutely spot on.Sharp,clear,vibrant colours with great contrast.
    The problem now for me is do I do a third set of the same,(and at £700 a real bargain if it lasted!) or do I now go back to mainstream brands say Panasonic or Phillips,with the problems you guys seem to have on here.
    As it would seem there is a lot of tube swapping,and from what I have seen and read regarding Phillips stuff put in Daewoo,would that mean that my distorted screen is a Phillips?
    Any one with help would be appreciated,or advice,especially if you have or no of my current set.
  2. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
    Change it and get a Toshiba 32ZD26P its fantastic and havn't heard of anyone having any probs with it :)
  3. Phil.LFC
    Phil.LFC
    Mar 31, 2002
    730
    Staffordshire
    +57
  4. Kentish
    Kentish
    Jun 15, 2002
    23
    Sorry I should have added that I must have 3 scarts,100 hz,video-s socket and av input.
    Sound issues are not a problem as I put all sound through my Yamaha av amp.
    Most tv watched is Sky digital,and some dvd,s.
    Hope you can help guys,and thanks for the earlier replys.
  5. Oblivion
    Oblivion
    Feb 23, 2002
    526
    Behind You
    Go for the Tosh 32ZD26P awsome TV - None of the usual problems.
    Paul
  6. Kentish
    Kentish
    Jun 15, 2002
    23
    OK,thanks for the replies,
    it looks like I might be chosing between the Tosh 32zd26 and the Panasonic 32pb50.
    I,m not sure bout the Phillips pixel plus sets,never have been to sure about anything Phillips.
    Any thoughts further on these?
  7. Kentish
    Kentish
    Jun 15, 2002
    23
    Going for a Toshiba 32ZD26,getting it for 999.92 from Empire Direct.
    Anyone seen the price at Robert Whyte when you click on the shopping trolley when you go for a 36ZD26? £885!! plus delivery
    Must be a mistake.
  8. JSW
    JSW
    Feb 21, 2002
    4,284
    Staffs
    +333
